Edit, copy and rename a rule
- In the Overview pane, right-click the relevant rule.
- Select either:
Edit Rule or Copy Rule or Rename Rule. The wizard Manage Rule opens.
- If you select Copy Rule, the wizard opens displaying a copy of the selected rule. Click Finish to create a copy.
- If you select Edit Rule, the wizard opens and you can enter changes. Click Finish to accept the changes.
- If you select Rename Rule, you can rename the rule name text directly.
