H.265 video support
When you view Milestone cameras in the CCure 9000 client application, the following message appears when the camera is streaming H.265 video:
The CCure 9000 client does not support H.265 video from the XProtect VMS. The client component of the CCure 9000 system is currently only available in a 32-bit option. Also, the 32-bit compatible MIP SDK from Milestone currently does not support H.265.
