Create a view
To create new views with different layouts and content combinations:
在工作区工具栏中,选择设置。
On the Views pane, select the view group to add the view to.
At the bottom of the Views pane, select Create new view
Choose a layout and number of view items.
Name the view.
再次选择设置可退出设置模式并保存修改。
If your system administrator changes camera properties and user permissions in the XProtect VMS system, it may require you to re-create one or more views.
