Play sound notification on event
You can configure XProtect Smart Client to play sound notifications when specific events related to a camera occur.
Your system administrator must have configured notifications on events on the XProtect VMS system server.
В панели инструментов рабочей области выберите Настройка.
2. Select the view and the view item you want to enable sound notifications for.
On the Properties pane, in the Sound on motion detection list select:
Always off: Disable sound notifications for events.
Always on: Play a sound notification for each detected event.
To apply the same settings for all camera, hotspot, and carousel view items, define the settings for one view item, then select Apply To All in the Properties pane.
Выберите Настройка еще раз, чтобы выйти из режима настройки и сохранить изменения.
