Select a fixed live stream
If your system administrator has set up camera to send multiple streams, you can choose a live stream that uses less bandwidth.
В панели инструментов рабочей области выберите Настройка.
On the Views pane, select the view and the camera view item to replace.
On the Properties pane, expand the Live stream list and select your preferred live stream option.
If your XProtect VMS uses adaptive streaming, select Default.
To apply the same settings for all camera, hotspot, and carousel view items, define the settings for one view item, then select Apply To All in the Properties pane.
Выберите Настройка еще раз, чтобы выйти из режима настройки и сохранить изменения.
