Add a hotspot to a view
A hotspot view item displays video feeds in a higher resolution enabling users to see details more clearly while also saving bandwidth on your remote connections.
There are two types of hotspots:
Global hotspots: Display the selected camera, whether it’s in the main window or a secondary display.
Local hotspots: Display the selected camera within the local display.
It’s recommended to add a hotspot to the largest view item, such as the large view item in a 1+7 view.
Select the view.
В панели инструментов рабочей области выберите Настройка.
On the System overview pane, drag the Hotspot item to the relevant view item.
(optional) On the Properties pane, modify the properties for the hotspot.
Выберите Настройка еще раз, чтобы выйти из режима настройки и сохранить изменения.
