Basic steps – Network
Use secure and trusted networks connection
Network communications must be secure, whether or not you are on a closed network. By default, secure communications should be used when accessing the VMS. For example:
Otherwise, credentials may be compromised and intruders might use them to access the VMS.
Configure the network to allow client computers to establish secure HTTPS sessions or VPN tunnels between the client devices and the VMS servers.
Learn more
The following control(s) provide additional guidance:
  • NIST SP 800-53 SI-2 Flaw remediation
  • NIST SP 800-53 CM-6 Configuration Settings
  • NIST SP 800-53 SC-23 Session Authenticity
Use firewalls to limit IP access to servers and computers
Milestone recommends that you use secure connections, and the following additional steps:
  • Use secure device authentication
  • Use TLS
  • Use device whitelisting to authenticate devices
  • Use firewalls to limit network communication between servers and client computers and programs.
All XProtect components and the ports needed by them are listed in individual sections below. To ensure, for example, that the firewall blocks only unwanted traffic, you need to specify the ports that the XProtect VMS uses. You should only enable these ports. The lists also include the ports used for local processes.
They are arranged in two groups:
  • Server components (services)—Offer their service on particular ports which is why they need to listen for client requests on these ports. Therefore, these ports need to be opened in the Windows Firewall for inbound connections.
  • Client components (clients)—Initiate connections to particular ports on server components. Therefore, these ports need to be opened for outbound connections. Outbound connections are typically open by default in the Windows Firewall.
If nothing else is mentioned, ports for server components must be opened for inbound connections, and ports for client components must be opened for outbound connections.
Do keep in mind that server components can act as clients to other server components as well.
The port numbers are the default numbers, but this can be changed. Contact Milestone Support, if you need to change ports that are not configurable through the Management Client.
Server components (inbound connections)
Each of the following sections list the ports which need to be opened for a particular service. In order to figure out which ports need to be opened on a particular computer, you need to consider all services running on this computer.
Restrict remote access to the Management Server by adding firewall rules to only allow Recording Servers to connect to TCP port 9000.
Serviço Management Server e processos relacionados
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
80
HTTP
IIS
Todos os servidores e o XProtect Smart Client e o Management Client
A finalidade da porta 80 e da porta 443 é a mesma. No entanto, qual porta o sistema de gerenciamento de vídeo usa depende se você usou certificados para proteger a comunicação.
  • Se você não protegeu a comunicação com certificados, o VMS usa a porta 80.
  • Quando você protege a comunicação com certificados, o VMS usa a porta 443, exceto para comunicação do servidor de eventos com o servidor de gerenciamento. A comunicação do servidor de eventos com o servidor de gerenciamento usa o Windows Secured Framework (WCF) e autenticação do Windows na porta 80.
443
HTTPS
IIS
445
TCP
Management Server Manager.
Ativar usuários do Active Directory do Windows a serem atribuídos às funções.
6473
TCP
Management Server Manager ícone de bandeja, conexão local apenas.
Exibindo o status e gerenciando o serviço.
8080
TCP
Servidor de gerenciamento
Apenas conexão local.
Comunicação entre processos internos do servidor.
9000HTTPServidor de gerenciamentoServiços Recording ServerServiço da web para comunicação interna entre servidores.
12345
TCP
Comunicação entre o sistema e os destinatários Matrix.
Você pode alterar o número da porta no Management Client.
12974
TCP
Serviço Windows SNMP
A comunicação com o agente de extensão SNMP.
Não use a porta para outros fins, mesmo que o seu sistema não use SNMP.
Nos sistemas XProtect 2014 ou mais antigos, o número da porta era 6475.
Nos sistemas XProtect 2019 R2 e anteriores, o número da porta era 7475.
SQL ServerServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
1433
TCP
SQL Server
Como armazenar e recuperar configurações através do Identity Provider.
1433
TCP
SQL Server
Serviço Event Server
Como armazenar e recuperar eventos através do Identity Provider.
1433
TCP
SQL Server
Serviço Log Server
Como armazenar e recuperar entradas de registro através do Identity Provider.
Data CollectorServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
7609
HTTP
IIS
No computador do servidor de gerenciamento: Serviços Data Collector em todos os outros servidores.
Em outros computadores: Serviço Data Collector no servidor de gerenciamento.
Monitor do sistema.
Event ServerServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
1234
TCP/UDP
Qualquer servidor enviando eventos genéricos para o seu sistema XProtect.
Ouvir eventos genéricos de sistemas ou dispositivos externos.
Apenas se a fonte de dados relevante estiver ativada.
1235
TCP
9090
TCP
Qualquer sistema ou dispositivo que envia eventos analíticos para o seu sistema XProtect.
Ouvir eventos de análise de sistemas ou dispositivos externos.
Só é relevante se o recurso Eventos de Análise estiver ativado.
22331
TCP
Configuração, eventos, alarmes e dados do mapa.
22332
WS/WSS
HTTP/HTTPS*
API Gateway e o Management Client
Assinatura de evento/estado, API REST de eventos, API Websockets Messaging e APIREST  de alarmes.
22333
TCP
Plug-ins e aplicativos MIP.
Mensagens MIP.
*Um erro 403 será apresentado durante a tentativa de acessar HTTP para visualizar um endpoint exclusivo de HTTPS.
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
25
SMTP
Serviço Recording Server
Câmeras, codificadores e dispositivos de E/S.
Ouvir as mensagens de eventos de dispositivos.
A porta está desativada por padrão.
(Obsoleto) Habilitar isto abrirá uma porta para conexões não criptografadas e não é recomendado.
5210
TCP
Servidor do sistema de gravação ininterrupta.
Mesclagem dos bancos de dados após um servidor do sistema de gravação ininterrupta (failover) ter sido executado.
5432
TCP
7563
TCP
XProtect Smart Client, Management Client
Recuperando fluxos de vídeo e áudio, comandos PTZ.
8966
TCP
Recording Server Manager ícone de bandeja, conexão local apenas.
9001HTTPServiço Recording ServerServidor de gerenciamento
Se diversas instâncias do Servidor de gravação estiverem em uso, cada instância precisa de sua própria porta. Portas adicionais serão 9002, 9003, etc.
11000
TCP
Servidores de gravação de failover
Sondagem (verificação regular) do estado dos servidores de gravação.
12975
TCP
Nos sistemas XProtect 2014 ou mais antigos, o número da porta era 6474.
Nos sistemas XProtect 2019 R2 e anteriores, o número da porta era 7474.
65101
UDP
Ouvir notificações de eventos dos drivers.
Além das conexões de entrada para o serviço Recording Server listado acima, o serviço Recording Server estabelece conexões de saída para:
  • Câmeras
  • NVRs
  • Sites interconectados remotos (Interconectar ICP Milestone)
Serviço Failover Server e serviço Failover Recording Server
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
25
SMTP
Serviço Failover Recording Server
5210
TCP
5432
TCP
7474
TCP
7563
TCP
8844
UDP
Comunicação entre serviços do Failover Recording Server.
Comunicação entre os servidores.
8966
TCP
Failover Recording Server Manager ícone de bandeja, conexão local apenas.
8967
TCP
Failover Server Manager ícone de bandeja, conexão local apenas.
8990
HTTP
Monitorar o status do serviço Failover Server.
9001HTTPServiço Failover ServerServidor de gerenciamentoServiço da web para comunicação interna entre servidores.
Além das conexões de entrada para o serviço de servidor de emergência/Failover Recording Server listado acima, o serviço servidor de emergência/Failover Recording Server estabelece conexões de saída para os gravadores e câmeras regulares e para Vídeo Push.
Log ServerServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
22337
HTTP
Serviço Log Server
Todos os componentes da XProtect, exceto o servidor de gravação.
Escreva para, leia do e configure o servidor de registros.
Essa porta utiliza HTTP, mas a comunicação é criptografada com segurança de mensagem que utiliza a especificação WS-Security para proteger as mensagens. Para mais informações, consulte a segurança de mensagens em WCF.
Mobile ServerServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
8000
TCP
Serviço Mobile Server
Mobile Server Manager ícone de bandeja, conexão local apenas.
Aplicativo SysTray.
8081
HTTP
Clientes móveis, clientes da Web e Management Client.
Enviando fluxos de dados; vídeo e áudio.
8082
HTTPS
Clientes móveis e clientes da Web.
40001 - 40099HTTPServiço Mobile ServerServiço do servidor de gravação
Mobile Server Pré-carregamento de vídeo.
Esta porta está desativada por padrão.
LPR Server serviço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
22334
TCP
Serviço LPR Server
Servidor de eventos
Recuperando as placas de licença reconhecidas e o status do servidor.
Para conectar o Servidor de eventos é preciso ter o plug-in LPR instalado.
22334
TCP
Serviço LPR Server
LPR Server Manager ícone de bandeja, conexão local apenas.
Aplicativo SysTray.
Milestone Open Network BridgeServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
580
TCP
Serviço Milestone Open Network Bridge
Clientes ONVIF
Autenticação e solicitações para configuração de fluxo de vídeo.
554
RTSP
Serviço RTSP
Clientes ONVIF
Fluxo de vídeo solicitado para clientes do ONVIF.
XProtect DLNA ServerServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
9100
HTTP
Serviço DLNA Server
Dispositivo DLNA
Descoberta de dispositivos e fornecimento de configuração de canais DLNA. Solicitações de fluxos de vídeo.
9200
HTTP
Serviço DLNA Server
Dispositivo DLNA
Fluxo de vídeo solicitado para dispositivos DLNA.
XProtect Screen RecorderServiço
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
52111
TCP
Fornece vídeo de um monitor. Aparece e funciona da mesma forma que uma câmera no servidor de gravação.
XProtect Incident Manager service
Numero da porta
Protocolo
Processo
Conexões de...
Objetivo
80
HTTP
IIS
  • Se você protegeu a comunicação com certificados, o VMS usa a porta 443.
443
HTTPS
IIS
Learn more
  • NIST SP 800-53 CA-3 System Interconnections
  • NIST SP 800-53 SC-7 Boundary Protection
Use a firewall between the VMS and the Internet
The VMS should not connect directly to the Internet. If you expose parts of the VMS to the Internet, Milestone recommends that you use an appropriately configured firewall between the VMS and the Internet.
If possible, expose only the XProtect Mobile server component to the Internet, and locate it in a demilitarize zone (DMZ) with firewalls on both sides. This is illustrated in the following figure.
Learn more
Connect the camera subnet to the recording server subnet only
Milestone recommends that you connect the camera subnet only to the recording server subnet. The cameras and other devices need to communicate only with the recording servers. For more information, see Recording Server.
Learn more
  • NIST 800-53 SC-7 Boundary Protection
