Open a view and maximize a view item
To view live or recorded video, you select a view that contains the relevant video.
Select the main views tab.
On the Views pane, select the view containing the relevant video.
Alternatively, if the view has a shortcut number, you can select the view with * + [shortcut number] + Enter on the numeric keypad. For example, to select a view with shortcut number 1, press * + 1 + Enter.
Assigned numbers are shown in parentheses before the view names on the Views pane.
To maximize a view item to see the details in the content of the view item, select the view item and double-click or press Enter. To minimize, double-click or press Enter again.
See Default keyboard shortcuts and Assign a shortcut number to a view.
