Pan, tilt, and zoom in video with preset positions
Preset positions enable you to quickly move a PTZ camera to commonly used directions and zoom levels.
To make the PTZ camera move to a preset position:.
- Select the view item with the video from the PTZ camera.
On the camera toolbar, select PTZ
 to open the PTZ menu. -
In the PTZ menu, select a preset position from the list to move the camera to the desired direction and zoom level.
The PTZ icon appears green until the camera reaches the preset position.
Locked Preset Positions: Your system administrator can lock preset positions, indicated by a padlock icon on the PTZ menu. Locked positions cannot be changed.
Home Position: Selecting the preset position “Home” will move the camera to its home preset position.
