Preview live video from multiple cameras
You can preview live video from up to 25 cameras on a smart map at the same time. To view the recorded video, you can send it to a new floating window.
Select the smart map and find the cameras to view video from.
Select the cameras using one or more of these methods:
Press and hold the CTRL key at the same time as you select the cameras.
In the toolbar, select
Select multiple cameras, then select and drag to select the cameras within an area.
Double-click a cluster icon to zoom in and select the devices and potential sub-clusters inside the cluster.
Select at least one cluster to select all cameras in the clusters in one go.
Right-click any of the selected cameras or clusters and select Live preview, or press Enter.
To play back and investigate the video in more detail:
In the Preview window, select Independent playback.
Or, in the Preview window, select More, Send to window, and then New floating window.
