Default keyboard shortcuts
XProtect Smart Client includes default keyboard shortcuts to help you move/swap view items, reset view items, open views, and move content between views. For example, you can use your joystick or mouse to move a PTZ camera and use a keyboard shortcut to send the camera view item to a hotspot or other view at the same time.
You can multitask by using keyboard shortcuts and your mouse or joystick at the same time. For example, you can move a PTZ camera with your joystick and open a view with a keyboard shortcut.
Możesz także przypisać niestandardowe skróty klawiszowe dla czynności w XProtect Smart Client. Patrz Ustawienia klawiatury.
Keyboard keys |
To do this |
Enter |
Alt +[view number] + [view item number] |
/+Enter (numeric keypad only) |
Resets a view item to is default content. See Reset a view item or view. |
/+/+Enter (numeric keypad only) |
Resets a view to is default content. See Reset a view item or view. |
2, 4, 6, and 8 (arrow keys) (numeric keypad only) |
Select the view item next to the current one (right, left, above, or below). |
/+<camera shortcut number>+Enter (numeric keypad only) |
Replace video in a camera view item. Requirement: Your system administrator has assigned a shortcut number to the camera. Assigned numbers are shown in parentheses before the camera name on the Views pane. |
*+<view shortcut number>+Enter (numeric keypad only) |
Open a view and maximize a view item. Requirement: you have assigned a shortcut number to a view. Assigned numbers are shown in parentheses before the view names on the Views pane. |
