Blank screen monitoring (explained)
Blank screen monitoring is an operation mode where operators only see video when a situation requires their attention. The video wall does not display any cameras during normal operation. Only when an event occurs does the video wall display video from the related cameras. When the incident has been resolved, the monitors showing the video are cleared.
To enable blank screen monitoring, you must create and apply a presetClosedPredefiniowany układ dla przynajmniej jednego monitora Smart Wall w XProtect Smart Client. Ustawienia wstępne określają, które kamery są wyświetlane i w jaki sposób zawartość jest zorganizowana na każdym monitorze na ścianie wideo. that only has a view layout, but no cameras. Use rules to display the cameras associated with certain events on your video wall, then clear the monitors again. See also Create rules with Smart Wall presets.
