Create a view
To create new views with different layouts and content combinations:
Selecteer Instellingen op de werkruimtetaakbalk.
On the Views pane, select the view group to add the view to.
At the bottom of the Views pane, select Create new view
Choose a layout and number of view items.
Name the view.
Selecteer Instellen opnieuw om de modus Instellingen te verlaten en uw wijzigingen op te slaan.
If your system administrator changes camera properties and user permissions in the XProtect VMS system, it may require you to re-create one or more views.
