Assign a shortcut number to a view
Assign shortcut numbers to views so you can quickly switch between views. See Default keyboard shortcuts.
  1. Select the view you want to assign a shortcut number to.
  2. Selecteer Instellingen op de werkruimtetaakbalk.
  3. At the bottom of the Views pane, in the Shortcut field, enter a shortcut number, and then press Set.
    The shortcut number appears in parentheses before the view name.
  4. Selecteer Instellen opnieuw om de modus Instellingen te verlaten en uw wijzigingen op te slaan.
