Management Client Profiles (Client node)
This functionality is available in XProtect Corporate only.
Info tab (Management Client Profiles)
On the Info tab, you can set the following for Management Client profiles:
Component
Requirement
Name
Enter a name for the Management Client profile.
Priority
Use the up and down arrows to set a priority for the Management Client profile.
Description
Enter a description for the profile. This is optional.
Roles using the Management Client profile
This field shows the roles that you have associated with the Management Client profile. You cannot edit this.
Profile tab (Management Client Profiles)
De beschikbare functies zijn afhankelijk van het systeem dat u gebruikt. Zie de volledige lijst met functies, die beschikbaar is op de productoverzichtspagina op de Milestone website (https://www.milestonesys.com/products/software/xprotect-comparison/).
On the Profile tab, you can enable or disable the visibility of the following elements from the Management Client's user interface:
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the various features and functionality located in the Navigation pane.
Navigation element
Description
Basics
Allows the administrator user associated with the Management Client profile to see License Information and Site Information.
Remote Connect Services
Allows the administrator user associated with the Management Client profile to see Axis One-click Camera Connection.
Servers
Allows the administrator user associated with the Management Client profile to see Recording Servers and Failover Servers.
Devices
Allows the administrator user associated with the Management Client profile to see Cameras, Microphones, Speakers, Metadata, Input and Output.
Client
Allows the administrator user associated with the Management Client profile to see Smart Wall, View Groups, Smart Client Profiles, Management Client Profiles and Matrix.
Rules and Events
Allows the administrator user associated with the Management Client profile to see Rules, Time Profiles, Notification Profiles, User-defined Events, Analytics Events and Generic Events.
Security
Allows the administrator user associated with the Management Client profile to see Roles and Basic Users.
System Dashboard
Allows the administrator user associated with the Management Client profile to see System Monitor, System Monitor Thresholds, Evidence Lock, Current Tasks and Configuration Reports.
Server Logs
Allows the administrator user associated with the Management Client profile to see system, audit, and rule-triggered logs.
Access Control
Allows the administrator user associated with the Management Client profile to see Access Control features, if you have added any access control system integrations or plug-ins to your system.
Details
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the various tabs for a specific device channel, for example the Settings tab or Record tab for cameras.
Device channel
Description
Cameras
Allows the administrator user associated with the Management Client profile to see some or all camera-related settings and tabs.
Microphones
Allows the administrator user associated with the Management Client profile to see some or all microphone-related settings and tabs.
Speakers
Allows the administrator user associated with the Management Client profile to see some or all speaker-related settings and tabs.
Metadata
Allows the administrator user associated with the Management Client profile to see some or all metadata-related settings and tabs.
Input
Allows the administrator user associated with the Management Client profile to see some or all input-related settings and tabs.
Output
Allows the administrator user associated with the Management Client profile to see some or all output-related settings and tabs.
Tools Menu
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the elements that are part of the Tools menu.
Tool Menu option
Description
Registered Services
Allows the administrator user associated with the Management Client profile to see Registered Services.
Effective Roles
Allows the administrator user associated with the Management Client profile to see Effective Roles.
Options
Allows the administrator user associated with the Management Client profile to see Options.
Federated Sites
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the Federated Site Hierarchy pane.
