Create a view
To create new views with different layouts and content combinations:
작업 공간 도구 모음에서 설정을 선택합니다.
On the Views pane, select the view group to add the view to.
At the bottom of the Views pane, select Create new view
Choose a layout and number of view items.
Name the view.
다시 설정을 선택하여 설정 모드를 종료하고 변경 사항을 저장합니다.
If your system administrator changes camera properties and user permissions in the XProtect VMS system, it may require you to re-create one or more views.
