Create a view group
You can make it easier to find and manage your views by organizing them into groups. Your system administrator may already have set up some groups, but you can usually create your own within existing view groups.
작업 공간 도구 모음에서 설정을 선택합니다.
On the Views pane, select the Private or shared view group that you want to add a group to.
At the bottom of the Views pane, select Create new group
Name the group.
다시 설정을 선택하여 설정 모드를 종료하고 변경 사항을 저장합니다.
You can now create views within your new group.
