Play sound notification on event
You can configure XProtect Smart Client to play sound notifications when specific events related to a camera occur.
Your system administrator must have configured notifications on events on the XProtect VMS system server.
작업 공간 도구 모음에서 설정을 선택합니다.
2. Select the view and the view item you want to enable sound notifications for.
On the Properties pane, in the Sound on motion detection list select:
Always off: Disable sound notifications for events.
Always on: Play a sound notification for each detected event.
To apply the same settings for all camera, hotspot, and carousel view items, define the settings for one view item, then select Apply To All in the Properties pane.
다시 설정을 선택하여 설정 모드를 종료하고 변경 사항을 저장합니다.
