Vulnerabilities typically reported by scanning tools
Microsoft Windows, SQL server and 3rd party software
Scanning tools typically try to identify known vulnerabilities by examining the version numbers of Microsoft Windows and other software products installed in Windows. This includes SQL server, virus scanner, and virus definitions, plus other third-party software installed in Windows.
In case the scanning tool reports vulnerabilities for Microsoft Windows, the SQL server, or other third-party software installed in Windows, please update or patch Windows and all other software products to newest versions. Also ensure that you have followed all recommendations in the Milestone XProtect VMS Hardening Guide , before scanning again for vulnerabilities.
If vulnerabilities are still reported for Microsoft Windows, SQL Server, or any third-party software, report the vulnerability to Microsoft or the vendor of the third-party software.
Unsecure services, ciphers and hashing functions
If the scanning tool has detected unsecure services, ciphers, or hashing functions, ensure that you have followed all recommendations in the Milestone XProtect VMS Hardening Guide and the Milestone XProtect Certificate Guide , including disabling none-essential Windows services, ciphers, and hashing functions.
Scanning tools might report that the communication on certain XProtect VMS ports still use HTTP, even when certificates have been configured for all the XProtect VMS servers. In this case, consult the XProtect VMS documentation on ports used by the XProtect VMS. Some XProtect VMS ports use Windows Communication Foundation (WCF) that offers message-based security and encryption, instead of transport-level security (HTTPS).
You can also use the documentation of the ports used by the XProtect VMS to identify which ports are used by the Milestone XProtect VMSm d by Microsoft Windows, by or third-party software.
Secure Communication
If the scanning tool reports issues with secure communication for XProtect services, follow the recommendations in the Milestone XProtect Certificate Guide.
In particular take the recommended actions for these issues:
Communication not encrypted
Create or obtain valid certificates issued by a trusted external or internal certificate authority (CA), and apply them across all XProtect services/components and clients.
Certificate have expired
Create or obtain valid certificates issued by a trusted external or internal certificate authority, and apply them across all XProtect services/components and clients.
Certificate uses weak ciphers and hash algorithms
Create or obtain valid certificates issued by a trusted external or internal certificate authority that uses modern and secure ciphers and hash algorithms, and apply them across all XProtect services/components and clients.
Certificate are self-signed
Add the computers to a Microsoft Active Directory (AD) Windows domain that can issue valid and trusted certificates. Then obtain AD-issued certificates and apply them across all XProtect services/components and clients.
Alternatively, install a Public Key Infrastructure (PKI) service, create valid and trusted certificates, and apply them across all XProtect services/components and clients.
If the scanning tool reports issues with the Milestone XProtect services/components, make sure that you have installed the latest version of XProtect VMS , and that you have followed the recommendations in the Milestone XProtect VMS Hardening Guide and Milestone XProtect Certificate Guide.
If vulnerabilities are still found after you have followed the information in the Milestone XProtect VMS Hardening Guide and Milestone XProtect Certificate Guide, please report the vulnerability to Milestone using our vulnerability form. Milestone investigate the reported vulnerability and address any validated vulnerabilities according to our Vulnerability Management Policy.
Camera and other equipment vulnerabilities
Vulnerabilities found in cameras, network equipment, network-attached storage systems, or other devices used in conjunction with the XProtect VMS, must be reported to the vendor of the equipment.
