License plate styles and aliases
License plate styles (explained)
Lo stile di una targa comprende un insieme di caratteristiche descrittive della targa, incluso:
Dimensioni e forma della targa
Formato e font del testo
Colori
Tipo di veicolo su cui è applicata la targa
See a list of all license plate styles supported by XProtect LPR.
You can group license plate styles into aliases. See Aliases (explained).
Aliases (explained)
A license plate style alias (alias) is a group of license plate styles. You can group license plate styles into an alias by creating the alias and assigning the alias to the license plate styles of your choice.
Aliases are optional. Using them is beneficial because:
Aliases help you categorize license plate styles according to your license plate recognition needs. See Example scenario
You specify the name of an alias. License plate styles have long and complex names that might be difficult to work with. Using aliases, you can specify a more descriptive group name
You can add aliases to match lists. See Edit match lists
The XProtect Smart Client operator can add aliases to match lists
Find license plate styles used in your system
Every country module contains license plate styles. When you enable a country module, all the license plate styles that belong to that country module are also enabled.
To see a list of all license plate styles enabled in your system:
Select Site Navigation > Servers > License plate style aliases > Assign aliases.
In the License plate style column, see a list of all license plate styles enabled in your system.
Match lists support aliases but not individual license plate styles. If you want to add a license plate style to a match list, first assign an alias to the license plate style. See Group license plate styles into aliases. Next, add the alias to the match list. See Edit match lists.
Add, edit, delete aliases
Select Site Navigation > Servers > License plate style aliases > Configure aliases.
Select:
Add to create an alias and specify an alias name
Edit to rename an alias
Delete to remove an alias
To group multiple license plate styles into an alias, you need to assign an alias to the license plate styles.
For each license plate style that you want to assign an alias to:
Select the dropdown in the Alias column.
Select the alias of your choice.
Example scenario
In this example, let's create aliases and assign them to license plate styles in the Denmark country module.
To follow along, open your Management Client and have the Denmark country module enabled.
For our license plate recognition needs, we decide to categorize license plate styles in the Denmark country module into the following groups:
Commercial
Motorcycle
Private
Standard
With the Denmark country module already enabled, let's first create the aliases, and then assign them to license plate styles.
Create aliases
Select Add to create an alias.
Let's create the four aliases:
- DK_COMMERCIAL
- DK_MOTORCYCLE
- DK_PRIVATE
- DK_STANDARD
Next, let's group license plate styles into aliases by assigning the new aliases to the license plate styles.
Assign the aliases to license plate styles
For each license plate style that you want to assign an alias to, select the dropdown in the Alias column and select the alias of your choice.
We assign aliases to license plate styles in the Denmark country module as follows:
License plate style |
Alias |
DK_COMMERCIAL |
DK_MOTORCYCLE |
DK_PRIVATE |
DK_STANDARD |
Note that we assigned the DK_MOTORCYCLE alias to only one license plate style. We did that because we want to use this specific license plate style on a match list, and match lists support aliases but not individual license plate styles.
In this example, we created aliases and assigned them to license plate styles. A possible next step is to add the aliases to match lists. That way, we can associate different groups of license plate styles with different LPR events. For example, we can open a gate to a vehicle only if the license plate style of the vehicle is part of the DK_COMMERCIAL alias. See Match lists.
