Viewing Matrix content
The Matrix feature is useful for sharing live video streams when you discover an incident. You and your colleagues can send live video streams to each other through shared views with Matrix view items.
If your system administrator has defined rules, these can also trigger sharing of video when events occur.
You can recognize a Matrix view item by the
icon in the title bar. If your view contains multiple Matrix items, the primary item shows the first received video stream. The next streams are shown in the primary item, which then pushed the previous streams to secondary items.
In playback mode, Matrix items display the last sent video.
