The user interface of XProtect Smart Client – Player
Playback mode in XProtect Smart Client – Player.
Number Description
1
Investigate the exported recordings in playback mode, and run searches on the Search tab.
2
Select the view that contains the cameras that you’re interested in.
3
In the main timeline, drag the timeline tracks back and forth to browse the recorded video.
4
Use the timeline controls in the main timeline to play back video or jump to a specific moment in time.
5
Change the time span of the timeline track. The range is five minutes to four weeks.
6
Change the speed of the playback.
7
Copy a still imageClosedA single still image. to the clipboard, so you can paste it into, for example, a document, or print a surveillance report with a still image and related information.
8
Start search in a new search window with the cameras in the current view preselected.
