There are two scenarios where digital signatures are excluded during the export process:
- If there are areas with privacy masks, digital signatures for the recording server will be removed in the export.
- If the data you are exporting is very close to the current date and time, the digital signature for the recording server might not be included for the whole sequence.
The export process will complete, but when you verify the signatures, you will see that the digital signatures for the recording server were removed or only partially added.
