Searching
On the Search tab, you can make advanced searches across multiple cameras to find and investigate an incident. This is useful, for example, if:
- There are many cameras in your system, and you are uncertain as to which cameras recorded the incident
- You want to find all video sequences within a certain timespan, for example if the cameras record only occasionally
- You want to find video sequences with motion, for example, to identify when a specific package was removed from a shelf
- You want to investigate or revisit bookmarked incidents
- You want to find video sequences associated with alarms, for example alarms in a certain state that are assigned to a specific operator
- You want to find video sequences associated with events, for example events that come from a specific source or server
- You want to find video sequences that include people, for example people of a certain age or height
- You want to find video sequences that include vehicles, for example a truck with a specific license plate number. Searching for vehicles is also available if you have XProtect® LPR installed in your system.
- You want to find video sequences recorded at a certain location
