Events and alarms
In XProtect, events and alarms are core features that enable you to monitor cameras and other devices in the system and to respond to security incidents in XProtect Smart Client.
  • Events refer to specific incidents detected by the VMS, such as motion detection, camera tampering, or system status changes. These events are typically generated by connected devices like cameras, sensors, or the VMS itself. Each event is logged with relevant details, such as the time, location, and type of incident.
  • Alarms are triggered responses to predefined events. When a particular event meets the criteria set within the XProtect VMS, an alarm is activated. You can configure alarms to prompt various actions, such as notifying security personnel, initiating recording, or triggering automated system responses like locking doors or turning on lights. When an incident triggers an alarm, a map or smart map can be displayed to give you geographical awareness of where the incident has taken place. You can receive desktop and sound notifications in Windows that appear whenever an alarm is triggered. For availability of maps, smart maps, and desktop notifications in your XProtect Smart Client setup, consult your system administrator.
Together, events and alarms provide you with a strong framework within your VMS for identifying, analyzing, and responding to potential security threats. You can use maps, smart maps, and Windows notifications for quick response to alarms.
Events
An event in XProtect VMS is a predefined incident that can be set up to trigger an alarm. Events are either predefined system incidents or user-defined events, for example analytics events or generic events. Events are not necessarily linked to an alarm, but they can be.
Typically, events are activated automatically and in the background, for example, through detected motion or by data from other applications. You can also manually activate events. The VMS uses events to trigger actions, such as starting or stopping recording, changing video settings, activating outputClosedData going out of a computer. On IP surveillance systems, output is frequently used for activating devices such as gates, sirens, strobe lights, and more., or combinations of actions.
When you activate an event from your XProtect Smart Client, it automatically triggers actions on the VMS system, for example recording on a particular camera with a particular frame rateClosedA measure indicating the amount of information contained in motion video. Typically measured in FPS (Frames Per second). for a particular period of time. Your system administrator determines what happens when you manually activate an event.
Alarms
This feature is only available in certain XProtect VMS systems. For more information, see the product comparison chart: https://www.milestonesys.com/products/software/xprotect-comparison/
On the XProtect VMS server, virtually any kind of incident or technical problem - events - can be set up to trigger an alarm. Alarms and events can all be viewed on the Alarm Manager tab, which provides a central overview of your VMS incidents, status, and possible technical problems.
You cannot set up alarm triggers yourself in the XProtect Smart Client. Your system administrator sets up alarm triggers when they configure the XProtect VMS system. The Alarm Manager tab is either displayed or hidden depending on the settings defined by your system administrator.
The Alarm Manager tab provides a dedicated view for your alarm or event handling. The tab itself displays the number of active alarms. More than nine alarms are shown with a 9+ alarms. The Alarm Manager tab includes an alarm list, an alarm preview for previewing video associated with individual alarms or events, and possibly also a map that displays the geographical location of the camera associated with the alarm.
The relationship between events and alarms
Incidents or technical problems that occur in your XProtect system are known as events. The term event refer to any occurrence or activity captured by the surveillance system that may require user attention or action. For example, if you have motion detection enabled on your cameras and motion is detected that detects motion, this is an event.
For example, if you have motion detected enabled on cameras in your system and movement is detected on a camera where motion detection is set up, this is an event.
To respond to events, your system administrator sets up alarms in XProtect. When an event is activated, an alarm is triggered and displayed in XProtect Smart Client.
For example, when the motion detection event is triggered, a corresponding alarm is shown in XProtect Smart Client to indicate that motion was detected.
You can view alarms and events on the Alarm Manager tab, which provides a central overview of your incidents, statuses, and possible technical problems. Users of XProtect Smart Client cannot set up alarm triggers directly. The system administrators can set up alarm triggers when they configure the XProtect VMS system.
Your system administrator defines whether to display or hide the Alarm Manager tab.
The Alarm Manager tab provides users with a dedicated view for alarm or event handling. The tab itself displays the number of active alarms. When more than nine alarms have been triggered, they are indicated with a notification button that says (9+) 9+ alarms.
The Alarm Manager tab also includes an alarm list, an alarm preview for previewing video associated with individual alarms or events, and possibly also a map that displays the geographical location of the camera associated with the alarm.
Manually activate events
You can manually activate an event. There is no confirmation when you have activated an event. The list of eventsClosedA predefined incident occurring on the surveillance system; used by the surveillance system for triggering actions. Depending on surveillance system configuration, events may be caused by input from external sensors, by detected motion, by data received from other applications, or manually through user input. The occurrence of an event could, for example, be used for making a camera record with a particular frame rate, for activating outputs, for sending e-mails, or for a combination thereof. you can select is grouped by event server, and the camera or device that the event is associated with.
  • In live mode, expand the Event pane, then click Activate.
Global events appear under the relevant event server. If an event server is listed with a red icon, it is unavailable and you cannot activate events on it.
Using the Alarm list
The Alarm List displays incoming alarms. The most recent alarms are displayed at the top of the list. The alarm list can display several different types of alarms, including those triggered by MIPClosedShort for "Milestone Integration Platform". plug-in and analytic events coming from, for example, access control or license plate recognition.
Alarms or events with associated video are displayed with an icon that indicates there is video attached ().
  • To preview a still image from the time of the alarm or event, place your mouse over the icon.
  • To preview recorded video from the camera or cameras associated with the alarm or event, select the alarm or event in the list.
  • To stop a repeating alarm sound, select the alarm associated with the sound in the list.
In the alarm list, you can:
  • decide how you want the list to appear
  • filter the columns
  • drag the columns to different positions
  • right-click to show or hide certain columns.
The event list does not display system- or user-generated events, such as motion detection or archive failure.
The list is updated every three (3) seconds.
The alarm list in XProtect Smart Client.
To see a list of events, enter setup mode and select Event in the Properties pane. See also Alarm list settings.
Servers in alarm list
On the left-hand side of the alarm list, you can view the event servers that the alarms originate from.
Many XProtect VMS systems only have a single event server, but some systems consist of several event servers in a hierarchy. All the event servers you have access to are listed, and you can filter alarms by event servers.
Alarm states
Alarms can be in one of the following states:
New, In progress, On hold, or Closed.
You can see the state of each alarm in the Alarm List, in the State Name column. Use the Filters pane to filter according to certain criteria. Initially, all alarms are in the New state, but its state is updated when an alarm is being handled.
Filter alarms
There are several ways you can filter the alarm list, so it displays just the alarms or events that you are interested in.
  1. In the toolbar of the alarm list, click the Custom (filter applied) or No filter text. The text may be different, depending on the filter you've selected.
    Filter alarms in XProtect Smart Client.
  2. Enter the filter criteria on any of the columns you want to filter on. For example, if you enter a user ID in the ID field, the list only displays alarms assigned to that particular user.
  3. You can combine filters, for example State name and Owner (assigned to).
  4. To return to the unfiltered alarm list, click the Clear filter button.
  5. To sort the content of the alarm list, click the title of the column.
If your alarm handling views contain map content, you can also filter the alarm list by right-clicking an element (camera, event server, or similar) on the map, then selecting Show alarms. This makes the alarm list show only alarms from the selected element.
Responding to alarms
Viewing and editing details of an alarm
The are different ways you can respond to alarms.
  • You can go to any view where you have added the Alarm List and double-click an alarm. The alarm opens in a separate window, where you can preview the alarm incident and its associated live video.
  • Depending on how your XProtect VMSClosedShort for "Video Management Software". system is configured, you might also receive alarm desktop notifications. Such notifications stay on your screen for 15 seconds. When you click a notification, it takes you directly to the Alarm Manager tab and opens the alarm window.
  • You can also respond to the alarm by changing the fields in the table below:
Field Description
State
The state of the alarm indicates if someone has take care of the event. You can change the state of the alarm. Typically, you would change the state from New to In progress, and then later to On hold or Closed.
Priority
Change the priority of the alarm.
Assigned to
Assign the alarm to a user in your organization, including yourself. The person you assign the alarm to becomes the owner of the alarm, and will appear in Owner column of the alarm list.
Comment
Write comments and remarks that are added to the Activities section. Comments typically relate to the actions you have taken. For example, “Suspect detained by Security”, “Suspect handed over to police,” or “False alarm.”
The Comment field appears at the bottom of the window.
Activities
The activities summarize how you have handled the alarm. The Activities section automatically includes:
  • any changes you or your colleagues make to alarm state or priority
  • any reassigning of alarms between users
  • any comments added.
Depending on the configuration of the XProtect VMS server, the alarm can contain instructions about what to do when receiving the alarm. The instructions are defined on the server-side as part of the alarm definition. When that is the case, the activities are automatically displayed when you edit the alarm.
Print
Print a report that contains information about the alarm, such as the alarm history and a still imageClosedA single still image. from the time of the alarm, if an image is available.
Acknowledge alarms
When you have received an alarm, you can acknowledge the alarm to indicate that you are going to take care of it. In a system with many users, acknowledging the alarm makes it easier for all users to see who is handling what. You can only acknowledge new alarms.
  1. In the alarm list, right-click the alarm and select Acknowledge. The alarm state changes to In progress.
  2. To acknowledge multiple alarms at the same time, press and hold down the CTRL key, and then select the alarms you want to acknowledge.
  3. Double-click an alarm to edit the details of the alarm, for example assigning the alarm to someone and adding instructions.
Disable all new alarms on selected event types
If an event is triggering false alarms, you might want to disable all new alarms on this type of event for some time.
For example, if there is a lot of movement around a camera and the movement is causing several false alarms, you can disable alarms on motion detection for this camera for 10 minutes. This way, false alarms won't disturb you, and you can focus on the alarms that need your attention. Disabling alarms affects all operators who are connected to the XProtect VMS system that you are also connected to.
You can disable all new alarms using the Alarm Manager or a map.
  1. Using the Alarm Manager: in the alarm list, right-click an alarm and select Disable all new alarms.
    Using a map: right-click an alarm and select Disable all new alarms > Disable.
    The Disable all new alarms window appears.
    Disable alarms based on event types in XProtect Smart Client.
  2. In the Events that will not trigger alarms list , select which event types should not trigger alarms.
  3. Specify until when or for how long the selected event types should not trigger alarms .
  4. Optionally, add a comment about why you are disabling alarms on the selected event types .
If you right-click an event, an overview of disabled events appears, and you can see which event is disabled and what the time-out of that event is.
You disable alarms per event server. If an event server fails and another event server takes over, any alarms disabled on the failed event server will again appear as alarms.
Ignore alarms on maps
On a map, you can ignore an alarm for an element for a duration of time. For example, if a camera is being repaired and therefore disconnected, you might want to ignore the error showing up on the map during the repair. When you ignore an alarm on a map, this does not remove the alarm from the alarm list, just the map.
Ignore alarms on maps in XProtect Smart Client.
Close alarms
After acknowledging an alarm, typically you assign it to someone who investigates what is going on. During that time, the alarm will be in the state In progress. After handling the alarm, you can close it.
To close an alarm, in the Alarm List, do one of either:
  • Right-click the alarm and select Close.
  • Double-click the alarm, and in the State list, select Closed.
Print alarm reports
You can print a report with information about the alarm, including the alarm history and, if available, a still image from the time of the alarm. However, you cannot use this feature if you have selected multiple alarms in the alarm list. To comply with GDPR rules, by default, the name of the report creator is not shown in the printed report, while the name of the person who printed the report is. To display all names connected to the report, select the Display names button.
  1. In the alarm list, right-click the alarm.
  2. Select Print. A window appears.
  3. To add a note, enter the text in the Note field.
  4. Click the Print button.
Get statistics on alarms
Get statistical data about the alarms triggered in your XProtect VMS system over the:
  • Last 24 hours
  • Last 7 days
  • Last 30 days
  • Last 6 months
  • Last year
The Alarm Report window shows two graphs that display the number of alarms filtered by categories, for example Priority or State, allowing you to compare the two graphs side by side.
Steps:
  1. In the Alarm List, click the Reports button. A window appears.
  2. Above the graphs, select the timespan, for example Last 24 hours.
  3. In the Select report list, select one of these categories:
    • Category
    • State
    • Priority
    • Reasons for closing
    • Site
    • Response time
  4. For each graph, select a sub-filter. For example if you selected State, you can select New in the first graph and In progress in the second. The graphs are populated.
  5. To print the graphs as a PDF report, click .
Alarms on maps
If your alarm handling view contains one or more map positions, you can view alarms on the maps too. Maps display alarms based on the geographical location of the camera, event server or other device triggering the alarms, so you can instantly see where the alarm originates from. You can right-click and acknowledge, disable, or suppress the alarm directly from the map.
Camera elements display video in thumbnail format when you move your mouse over it. When used together with alarms, the graphical elements on maps display red circles around them if alarms occur. For example, if an alarm associated with a particular camera occurs, the graphical element representing that camera will immediately get a red circle around it, and you can then click the camera element and not only view video from the camera, but also handle the alarm through a menu that appears.
If red is not an ideal color for signifying alarms on your maps, you can change this color.
Now, say the camera which has an alarm associated with it, is located on a street level map, but you are viewing a city level map. How will you then notice the alarm? No problem, thanks to hot zones—graphical representations linking different map hierarchy levels together. If an alarm is detected on the street level map, the hot zone on the city level map will then turn red, indicating that there is an alarm on a lower level map—even if there are map levels in between.
To return to an alarm list mode where you can see alarms from more than just the one element, click the required event server, priority or state in the alarm list.
Alarms on smart maps
If a device triggers an alarm and the device is added to your smart map, the alarm will appear as a red circle around the device or the icon for the cluster with the device inside. See Adding, deleting, or editing devices on smart map.
For more information about smart map icons, see Camera icons.
