Create a view group
You can make it easier to find and manage your views by organizing them into groups. Your system administrator may already have set up some groups, but you can usually create your own within existing view groups.
في شريط أدوات مساحة العمل، حدِّد إعداد.
On the Views pane, select the Private or shared view group that you want to add a group to.
At the bottom of the Views pane, select Create new group
Name the group.
حدِّد الإعداد مرة أخرى للخروج من وضع الإعداد وحفظ التغييرات.
You can now create views within your new group.
