CCure 9000: licenses explained
The CCure 9000 license required to integrate with Milestone XProtect is “Milestone XProtect Corporate” or "Milestone - XProtect Corporate - Integration." This doesn't mean that the only XProtect product that integrates with CCure 9000 is XProtect Corporate. XProtect Corporate, XProtect Expert, and XProtect Professional+ VMS products from Milestone are all tested and supported.
Licenses required for CCure 9000 are subject to change based on the version of software installed. There are two different types of integration licenses that could be used to enable the CCure XProtect Access integration.
  1. Milestone XProtect Corporate - SDK license
  2. Milestone - XProtect Corporate - Integration - web service API license
Both of these licenses will work. However, only the current version of the XProtect Access integration (1.4) is compatible with the web service API license. Also, only recent versions of the CCure 9000 software require the web service API license - versions 3.00.1 and higher. Older versions of the integration (1.3 and below) are not compatible with any version of  CCure that is 3.00.1 or higher.
There are three different product SKUs used to order the integration license based on the size of the CCure system (the number of readers). These license options apply to all versions of CCure 9000. This applies to both the SDK license and the web service API license.
License SKU Description
CC9-MSTVD-SM CCure 9000 Milestone XProtect Corporate Web Service Integration Small, Series L to N (0-64 readers)
CC9-MSTVD-MD CCure 9000 Milestone XProtect Coporate Web Service Integration Medium, Series P to R (65-999 readers)
CC9-MSTVD-LG CCure 9000 Milestone XProtect Corporate Web Service Integration Large, Series RP to T (1000+ readers)
XProtect Access uses a permanent connection to the CCure 9000 victor web service (to receive statuses and events) and uses extra connections for specific user operations, such as fetching configuration and executing commands. For optimal operation of XProtect Access, the feature license activated in CCure must support enough concurrent connections to the victor web service to handle the number of XProtect Access permanent and transient connections.
The victor web service is a requirement for the XProtect Access integration with CCure 9000. However, this licensed option is typically included.
