Minimum system requirements
Installing the plug-in or patch for Milestone AI Bridge does not affect the system requirements for any system components in your XProtect VMS.
Para obtener información acerca de los requisitos de sistema para las distintas aplicaciones del VMS y componentes del sistema, vaya al sitio web de Milestone (https://www.milestonesys.com/systemrequirements/).
For requirements for the hardware running your processing server, contact your IVA app integrator.
