XProtect Hospital Assist
XProtect Hospital Assist is designed exclusively for hospital units caring for patients in need of 24/7 or situational observation.
This XProtect VMS extension is a dedicated solution to remotely monitor patients which allows the hospital to:
Increase staff efficiency.
React to incidents rapidly.
Provide high-quality patient care.
If you have access to the XProtect Hospital Assist functionality, you can add sticky notes and enable privacy blur from a camera view item. In the Alarm Manager window, you can get notifications when a person falling is detected.
For information see https://doc.milestonesys.com/hospitalassist/v1/en-US/portal/index.htm.
