Matrix (configuration)
Add Matrix to views
To be able to send live video to a Matrix
A product integrated into some surveillance systems, which enables the control of live camera views on remote computers for distributed viewing. Computers on which you can view Matrix-triggered video are known as Matrix-recipients.-recipient, first you must add the Matrix item to a view. Only from within the view, can the operator send the video to a Matrix-recipient.
- In setup mode, in the System overview pane, drag the Matrix element to the view item where you want to add Matrix content. A blue border appears indicating that the view item has Matrix content.
- When you select a view item with Matrix content, you can specify its properties in the Properties pane.
When viewing live or recorded video, you can double-click a view item with Matrix content (or any view item with a camera) to maximize it. When maximized, video from cameras in the view item with Matrix content is displayed in full quality by default, regardless of your image quality selection. If you want to make sure that the selected image quality also applies when maximized, select Keep when maximized.
- Repeat for each view item with Matrix content you want to add.
Matrix settings
In setup mode, in the Properties (see Camera settings) pane, you can specify the settings for view items with Matrix content.
Name |
Description |
| Window index |
Change the ranking of the view item with Matrix content by choosing a different number. You can only choose a number in the range that corresponds to the number of Matrix view items in your view. 1 is the primary view item in which video from the newest event is always shown, 2 displays video from the previously detected event, 3 displays video from the event detected before the event in view item 2, and so on. |
| Connection settings |
Lets you specify the TCP |
