Define privacy masks
When you enable the privacy masking feature on the Privacy masking tab, a grid is applied to the camera preview.
- In the Site Navigation pane, select Devices.
 - Select the relevant camera in the Overview pane.
 - On the Privacy masking tab, to cover an area with a privacy mask, first select Permanent mask or Liftable mask to define if you want a permanent or liftable privacy mask.
 - Drag the mouse pointer over the preview. Left-click to select a grid cell. Right-click to clear a grid cell.
 - You can define as many privacy mask areas as needed. Areas with permanent privacy masks appear in purple and areas with liftable privacy masks in green.
 - Define how the covering of the areas should appear in the video when shown in the clients. Use the sliders to go from a light blurring to a full nontransparent mask.
Permanent privacy masks also appear on the Motion tab.
 - In XProtect Smart Client, check that the privacy masks appear as you defined.
