Create a report of your privacy masking configuration
The devices report include information about your cameras' current privacy masking settings.
To configure a report:
- In the Site Navigation pane, select System Dashboard.
 - Under Configuration Reports, select the Devices report.
 - If you want to modify the report, you can change the front page and the formatting.
 - Click Export, and the system creates the report as a PDF file.
For more information about reports, see Print a report with your system configuration.
