Add and configure a Management Client profile
If you do not want to use the default profile, you can create a Management Client profile before you can configure it.
- Right-click Management Client Profiles.
 - Select Add Management Client Profile.
 - In the Add Management Client Profile dialog box, enter a name and description of the new profile and click OK.
 - In the Overview pane, click the profile you created to configure it.
 - On the Profile tab, select or clear functionality from the Management Client profile.
