Hotspots (configuration)
Before you can use the hotspot
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views., you must:
- Add the hotspot to a view. See Add hotspots to views.
- Specify the hotspot settings. See Hotspot settings.
If your view contains a hotspot, and you click a camera, the video feed from the camera is displayed in a high resolution in the hotspot
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views. view item.
Steps:
On the workspace toolbar, select Setup to enter into setup mode.
- In the System overview pane, click and drag the Hotspot item to the required view item in the view. The view item displays a hotspot icon:
. - (optional) On the Properties pane, define the properties for the hotspot.
Select Setup again to exit setup mode and save your changes.
To save bandwidth, you can specify a low image quality for the other view items in your view and a high quality for the hotspot.
Hotspot settings
In the Properties (see Camera settings) pane, you can specify the settings for the hotspot
A particular position for viewing magnified and/or high quality camera images in XProtect Smart Client views.. The Live stream, Image Quality, Frame Rate, and Maintain Image Aspect Ratio settings apply to all cameras in the hotspot.
To make the properties appear, you must select the view item and then click Setup.
