Bookmarks (configuration)
This feature is only available in certain XProtect VMS systems. For more information, see the product comparison chart: https://www.milestonesys.com/products/software/xprotect-comparison/
Enable detailed bookmarks
To efficiently manage and search for your bookmarks, you can enable a setting that allows you to give your bookmarks a name and a description and to change the default time span for bookmarks.
On the global toolbar, select Settings and more
and then Settings
- Select the Functions tab.
- To enable detailed bookmarks for live video, locate the row with the Bookmark function in Live mode and change the setting to Add bookmark details.
- To enable detailed bookmarks for recorded video, locate the row with the Bookmark function in Playback mode and change the setting to Add bookmark details.
- Click Close to save the changes.
