Licenses (explained)
Free XProtect Essential+
If you have installed XProtect Essential+, you can run the system and eight device licenses for free. Automatic license activation is enabled, and hardware will be activated as you add it to the system.
Only when you upgrade to a more advanced XProtect product and need to change your SLC (Software License Code) (see Change the Software License Code), the rest of this topic and the other licensing-related topics in this documentation could be relevant for you.
Licenses for XProtect VMS products (except XProtect Essential+)
Software license file and SLCs
Yazılımınızı ve lisanslarınızı satın aldığınız zaman şunları elde edersiniz:
  • Eposta ile alınmak üzere bir sipariş teyidi ve SLC’nizin (Yazılım Lisans Kodu) adında ve .lic uzantılı bir yazılım lisans dosyası
  • Bir Milestone Care kapsamı
Your SLC is also printed on your order confirmation and consists of several numbers and letters grouped by hyphens like:
  • Product version 2014 or earlier: xxx-xxxx-xxxx
  • Product version 2016 or later: xxx-xxx-xxx-xx-xxxxxx
The software license file contains all information about your purchased VMS products, XProtect extensions, and licenses. Milestone recommends that you store the information about your SLC and a copy of your software license file in a safe place for later use. You can also see your SLC in the License Information window in Management Client. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information. You may need the software license file or your SLC when you, for example, create a My Milestone user account, contact your reseller for support, or if you need to make changes to your system.
Overall process for installation and licensing
To get started, you download the software from our website (https://www.milestonesys.com/downloads/). While you are installing (see Install a new XProtect system) the software, you are asked to provide the software license file. You cannot complete the installation without a software license file.
Once the installation is complete and you have added some cameras, you must activate your licenses (see License activation (explained). You activate your licenses from the License Information window in Management Client. Here you can also see an overview of your licenses for all installations on the same SLC. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.
License types
XProtect lisanslama sisteminde çok sayıda lisans türü bulunur.
Temel lisanslar
Minimum olarak, XProtect VYY ürünlerinden biri için temel bir lisansınız bulunur. XProtect uzantıları için bir veya daha fazla temel lisansınız da olabilir.
Aygıt lisansları
Minimum olarak, çok sayıda lisansınız bulunur. Genellikle, sisteminize eklemek istediğiniz bir kamera ile donanım aygıtı başına bir aygıt lisansına ihtiyacınız vardır. Ancak, bir donanım aygıtından diğerine ve donanım aygıtının bir Milestone desteklenen donanım aygıtı olup olmadığına bağlı olarak farklılık gösterebilir. Daha fazla bilgi için, bkz. Desteklenen donanım aygıtları ve Desteklenmeyen donanım aygıtları.
XProtect Mobile içinde video anlık bildirim özelliğini kullanmak isterseniz, sisteminize videoyu gönderebilecek mobil aygıt veya tablet başına bir aygıt lisansına da ihtiyacınız vardır.
Aygıt lisansları, kameralarınıza bağlı hoparlörler, mikrofonlar veya giriş ve çıkış aygıtları için gerekmez.
Genellikle, sisteminize eklemek istediğiniz bir kamera ile donanım aygıtı başına bir aygıt lisansına ihtiyacınız vardır. Ancak birkaç desteklenen donanım aygıtı birden fazla aygıt lisansı gerektirir. Donanım aygıtlarınızın kaç adet aygıt lisansını gerektirdiğini Milestone web sitesinde (https://www.milestonesys.com/support/tools-and-references/supported-devices/) desteklenen donanım listesinde görebilirsiniz.
16 kanala kadar olan video kodlayıcılar için, video kodlayıcı IP adresi başına sadece bir aygıt lisansına ihtiyacınız vardır. Bir video kodlayıcı bir veya daha fazla IP adresine sahip olabilir.
Ancak, video kodlayıcı 16'dan daha fazla kanala sahipse, video kodlayıcıda etkinleştirilmiş kamera başına ayrıca ilk 16 etkinleştirilmiş kamera için bir aygıt lisansı gerekir.
Desteklenmeyen bir donanım aygıtı, bir video kanalı kullanılarak etkinleştirilmiş kamera başına bir aygıt lisansı gerektirir.
Desteklenmeyen donanım aygıtları Milestone web sitesinde (https://www.milestonesys.com/support/tools-and-references/supported-devices/) desteklenen donanım listesinde görünmez.
Kamera lisansları Milestone Interconnect™
Milestone Interconnect çalıştırmak için, uzak sitelerden donanım cihazlarından videoyu görüntülemek için merkez sitenizdeki Milestone Interconnect kamera lisanslarına ihtiyacınız var. Gerekli Milestone Interconnect kamera lisansı sayısı, veri almak istediğiniz uzak sitelerdeki donanım cihazları sayısına bağlıdır. Bir merkezi nokta olarak sadece XProtect Corporate kullanılabileceğini unutmayın.
XProtect uzantılarının lisanları
Çoğu XProtect uzantısı ek lisans türleri gerektirir. Yazılım lisans dosyası, uzantı lisanslarınız hakkında bilgi de içermektedir. Bazı uzantılar, kendilerine ait ayrı yazılım lisans dosyalarına sahiptir. Uzantı lisansları hakkında daha fazla bilgiyi burada bulabilirsiniz:
  • XProtect Access (bkz. XProtect Access licenses)
  • XProtect LPR (bkz. XProtect LPR licenses)
  • XProtect Transact (bkz. Before you start)
  • XProtect Smart Wall aşağıdaki video duvarı ile ilgili lisansları gerektirir:
    • Bir video duvarında videoyu görüntüleyen kısıtsız bir sayıyı kapsayan XProtect Smart Wall için bir temel lisans
    XProtect Smart Wall kullanımı sadece bu ürünlerde desteklenir:
    • XProtect Corporate - XProtect Smart Wall için bir temel lisans, temel lisansa dahil edilmektedir
    • XProtect Expert - XProtect Smart Wall için ayrı olarak bir temel lisans satın alın
  • XProtect Incident Manager aşağıdaki lisansları gerektirir:
    • Tam XProtect Incident Manager kullanımını kapsayan bir temel lisans
    XProtect Incident Manager kullanımı yalnızca aşağıdaki Video Yönetim Yazılımı VYY ürünleri ve sürümlerinde desteklenmektedir:
    • XProtect Corporate için bir temel lisans, 2022 R2 XProtect Incident Manager ve sonraki sürümlerine dâhildir.
    • XProtect Expert-XProtect Professional+ XProtect Express+ 2022 R3 için ayrı olarak bir temel lisans satın alın XProtect Incident Manager
