Register new Axis One-Click camera
  1. To register a camera under an ST server, right-click it and select Register Axis One-Click Camera.
  2. In the window that opens, fill in the relevant information.
  3. Click OK.
  4. The camera now appears under the relevant ST server.
The camera can have the following color coding:
Color
Description
Red
Initial state. Registered, but not connected to the ST server.
Yellow
Registered. Connected to the ST server, but not added as hardware.
Green
Added as hardware. May or may not be connected to the ST server.
When you add a new camera, its status is always green. The connection status is reflected by Devices on Recording Servers in the Overview pane. In the Overview pane, you may group your cameras for an easier overview. If you choose not to register your camera at the Axis dispatch service at this point, you can do so later from the right-click menu (select Edit Axis One-Click Camera).
