Edit error filters
With error filters, you can customize the errors you see in the Errors page. You can modify the existing filters, depending on your current needs.
To edit a filter:
In the navigation pane, select Errors and then click Manage error filters.
Select an existing filter
and click Edit
- In the Edit filter window, you can change some of the properties. After applying your changes, click Save.
Related topics:
