Installing the OnGuard Video Web Package and Milestone Open Network Bridge
Installation of the Milestone Open Network Bridge and the OnGuard Video Web Package is required if you plan to use the OnGuard Web Client running OnGuard v8.0 and up. Ideally, you should install the OnGuard Video Web Package with Milestone ONVIF Bridge on a separate, independent server (not on the OnGuard machine, Milestone XProtect Management Server, or Milestone XProtect Recording Server).
For full details please refer to the OnGuard Video Web Package and Milestone Open Network Bridge (explained) section of this document.
