Software version compatibility
Integration with CCure 9000 Access Control system is supported with all XProtect VMS products which can support MIP integrations and with a rules system that supports the XProtect Access suite of functionality.
The most up to date compatibility information is located here: https://download.milestonesys.com/ccure9kxpa
Please verify the version of CCure 9000 you are running is compatible. Milestone always recommends that you run the latest versions of both CCure 9000 and XProtect.
