View exported video
When you receive exported video in the XProtect format, you also receive a version of XProtect Smart Client – Player.
Open the folder that contains the exported video and run the SmartClient-Player.exe file.
If the exported video is password protected, enter the password.
Select Connect.
From the timeline, select how you want to playback the video. For example, select play forward
If you have received exported video from many cameras, consider to view the video in an adaptive view.
