Adding cameras
Select the Video Recorder tab in the Digital Video section of the Video menu in the OnGuard System Administration application.
- To automatically import cameras from Milestone into OnGuard, right-click the video recorder entry and select Import from Recorder.
- The import from recorder window displays a list of cameras available on the specified recorder. You can then select the cameras that you want to import into OnGuard by clicking on them in the left pane. This moves them to the right pane.
- When you have selected all the required cameras for import, click OK.
- The selected cameras appear in the camera view.
