XProtect Access (usage)
If one or more access control systems have been integrated with your VMS
Short for "Video Management Software". system through the XProtect Access extension, you can monitor doors, control door states, investigate access control events, respond to access requests, and manage cardholder information.
Access control in live mode (explained)
In live mode, you can view live video from the cameras associated with access control sources, together with the list of events on the right-hand side of the video.
When you click any of the events in the list, the live video automatically pauses and changes to independent playback of the event. To go back to viewing live video, either click the event again or click the Independent playback icon on the camera toolbar (see View recorded video independently of the main timeline).
If the system and the event hold cardholder
A person that possesses a card that is recognizable to an access control system and gives access to one or more areas, buildings or similar.
See also access control. information, you can click the search icon next to the cardholder name on a selected event to jump to the Access control tab and view all events associated with this person.
Monitor doors via maps
If you use the map functionality to support your surveillance and access control tasks, you can add access control units to a map:
- In setup mode, expand the System overview pane.
- Select Map from the list and drag it to a view item.
- Locate the map file and click OK.
- From the map toolbox that appears, click Add access control.
- In the list that appears, drag the relevant access control unit, for example a door, onto the map. A door icon appears on the map.
- Click Setup to change to live viewing.
- When a person requests access, the door unlocks. The door unlocks because someone grants access via a command button on the access request notification or even on the map itself. Once the access is granted, the door icon turns green and appear as an open door.
- When the door is locked again, automatically or manually, the door icon turns red and appear as a closed door.
- You can right-click the door icon to, for example, trigger commands.
Since the state of the access control units are always visible, a map used in this way is a quick way to get a graphical overview of the states of the access control units for the area or building you are monitoring.
Investigating access control events
Search and filter access control events
There are several ways you can filter the event list, so it displays the data that you are interested in.
- On the Access control tab, select Events list.
- Click any of the filters at the top of the list and specify the criteria.
- Alternatively you can right-click a specific time, event, source or cardholder
See also access control. within the list and filter using that value.
Any filters you apply are immediately reflected in the list.
Events list |
Description |
| Time |
Select one of the available periods to see data for that particular period. For example, click Today to see only events that took place today or use the custom interval to specify a particular period. If you select Live update, the list of events is updated instantly if new events occur that meet the filter criterion. The list displays maximum 100 events. You cannot search for cardholders when you work in live update mode. |
| Event |
Select one or more of the available event types directly from the list of event categories and uncategorized events or select between specific access control events. |
| Source |
Select one or more of the available sources directly from the list of doors or select between other sources (for example access points or controllers from the access control system) to view only events for those units. |
| Access Control System |
If your XProtect system integrates with multiple access control systems, select from which access control system you want to view events. |
| Cardholder |
Select one or more of the available cardholders. |
Events list (explained)
On the Access control tab, when you select an event, the preview on the right lets you view the related video sequence for the event. The preview camera title bar shows the camera related to the unit that triggered the event.
- If you have multiple cameras associated with a door, they all appear in the preview
- Standard playback options are available from the toolbar
- Related cardholder information appears below the video preview together with details about the selected event
- Click
to view live video or play back recorded video in a detached window
Export an access report
On the Access control tab, you can create and export a report of the event list to a PDF file when you are not in live update mode.
- Filter or search for the events you want in the report.
If the event count is very high, you will receive a recommendation to refine the search and thereby reduce the number of search results.
- Click the Access Report button.
- Fill out the fields. The report contains:
- Report name
- Report destination
- A list of the applied filters
- A comment field
- An option to include snapshots
- Click OK and await that the report is completed.
- In the top right corner, click Details and in the dialog box that appears, click Open.
The report opens in PDF format.
Switch to or from live update mode of the Events list
Instead of viewing live video of access control events in live mode, you work in live update mode on the Access control tab. The list of events is updated instantly if new events occur that meet the filter criterion.
- In the dropdown list of the filter where you usually select a period, select Live Update.
Next to the search field, you see that you have changed mode and the list is updated instantly when an event that meets the filter criterion occurs.
When you work in live update mode, you cannot search for cardholders and you cannot create an access report.
- To switch back from the live update mode, filter on a new period.
Monitor and control door states
The Doors list provides a list of the doors, access points and other access control units in each access control system, and their current state. This is useful if you, for example, need to know the state of a specific door.
There are several ways you can filter the doors list, so it displays the data that you are interested in.
- On the Access control tab, select Doors list.
- You can combine the filters or enter your criteria in the search field to search for doors.
- Alternatively you can right-click a door or a state within the list and filter using that value.
Doors list |
Description |
| Name |
Select one or more of the available doors, access points and uncategorized types or select between other access control units to view only states of those selected. |
If your XProtect system integrates with multiple access control systems, select from which access control system you want to view doors. |
| State |
Select one or more of the available states directly from the list of state categories and uncategorized states or select between specific access control states. |
Another way that you can monitor the door states for your surveillance area is by adding doors to a map (see Monitor doors via maps).
Doors list (explained)
On the Access control tab, when you select a door in the Doors list, the associated camera shows live video on the right-hand side of the screen together with detailed information.
- Standard independent playback options are available from the toolbar
- Action buttons allow you to perform certain commands related to that door, for example lock/unlock door. Available commands depend on your system configuration
- Information related to the selected door appears below the live video preview
- Click
Investigate cardholders
The Cardholders list provides a list of the cardholders in each access control system and their details. This is useful if you, for example, need detailed information about a specific person.
There are several ways you can filter the cardholders list, so it displays the data that you are interested in.
- On the Access control tab, select Cardholders list.
- Click the filter at the top of the list to specify the access control system from which you want to investigate cardholders. You can only work with one access control system at a time.
- You can combine the filters or enter your criteria in the search field to search for cardholders.
- Alternatively you can right-click a cardholder or a type within the list and filter using that value.
| Cardholders list | Description |
| Name |
Select one of the available cardholders to view detailed information about this person. |
| Type |
Select one of the available cardholder types to view the list of cardholders with this type. |
When you select a cardholder, the detailed information about this person appears on the right-hand side of the screen. Depending on your system this may include a picture or a link to manage the cardholder record in the access control system (see Manage cardholder information).
Access request notifications (explained)
Your organization may have chosen that only security personnel must open the doors, when people want to enter your building. If such conditions apply, you may, for example, receive access request notifications when a person wants to enter one or more areas. All conditions that trigger an access request notification have to be specified in the video management system. The notification displays live video related to the access request, allowing you to see the person who is requesting access. The name of the door that should open is shown as a headline, indicating, for example, Access Request - Front door. The door state (for example open, closed, or forced open) also appears. If you have multiple cameras associated with a door, they appear below each other.
Access request notifications are temporary. When you close an access request notification, the notification is no longer present in your system. If you close XProtect Smart Client while an access request notification is shown, the notification is not restored when you restart.
Managing access request notifications (explained)
Provided that XProtect Smart Client is running, access request notifications pop up on your screen even when you work in other applications.
Click
if you want to view the live video in a detached window.
Access requests stack up on each other in the access request notification window so that you can handle all incoming access request notifications from the same notification window. You can drag a notification to the other side of the screen or even to another screen if connected.
If needed, you can minimize the access request notification window to allow the functionality to continue in the background. The XProtect Smart Client icon blinks in the taskbar when you have new notifications.
Respond to access requests
Provided that your VMS
Short for "Video Management Software". system supports two-way audio and if a speaker and microphone is attached to the relevant camera that shows the access request notification, access request notifications allow you to speak and listen to the person who wants to enter:
- To listen to what the person requesting access is saying, click the
button. - To speak to the person requesting access, for example to give instructions on how to proceed or behave in the area, click and hold the
button. - To carry out other actions, use the command buttons to the right of the microphone and speaker buttons. The most typical action is to unlock a door for a person requesting access, but could also be to turn on the lights in the area close to the relevant entry.
Cardholder information may be available if your access control
A security system that controls the entering of persons, vehicles, or others into a building or area. system provides such information to the XProtect system. Examples of cardholder information: Cardholder's ID number, name, department, phone number, and authority level. Depending on your system configuration, you may be able to manage cardholder information (see Manage cardholder information).
