OnGuard and Oracle database compatibility
The Milestone XProtect OpenVideo integration with OnGuard isn't compatible with an OnGuard system that uses an Oracle database. The compatible and supported database technology for use with this integration is Microsoft SQL Server.
Using an Oracle database with OnGuard is an option that LenelS2 supports. The Milestone XProtect OpenVideo integration doesn't support OnGuard systems that use Oracle databases.
