Licenses (explained)
Free XProtect Essential+
If you have installed XProtect Essential+, you can run the system and eight device licenses for free. Automatic license activation is enabled, and hardware will be activated as you add it to the system.
Only when you upgrade to a more advanced XProtect product and need to change your SLC (Software License Code) (see Change the Software License Code), the rest of this topic and the other licensing-related topics in this documentation could be relevant for you.
Licenses for XProtect VMS products (except XProtect Essential+)
Software license file and SLCs
Når du køber din software og licenser, får du:
- En ordrebekræftelse og en softwarelicensfil navngivet efter din softwarelicenskode (SLC) med filtypenavnet .lic, som du modtager med e-mail
- En Milestone Care-dækning
Your SLC is also printed on your order confirmation and consists of several numbers and letters grouped by hyphens like:
- Product version 2014 or earlier: xxx-xxxx-xxxx
- Product version 2016 or later: xxx-xxx-xxx-xx-xxxxxx
The software license file contains all information about your purchased VMS products, XProtect extensions, and licenses. Milestone recommends that you store the information about your SLC and a copy of your software license file in a safe place for later use. You can also see your SLC in the License Information window in Management Client. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information. You may need the software license file or your SLC when you, for example, create a My Milestone user account, contact your reseller for support, or if you need to make changes to your system.
Overall process for installation and licensing
To get started, you download the software from our website (https://www.milestonesys.com/downloads/). While you are installing (see Install a new XProtect system) the software, you are asked to provide the software license file. You cannot complete the installation without a software license file.
Once the installation is complete and you have added some cameras, you must activate your licenses (see License activation (explained). You activate your licenses from the License Information window in Management Client. Here you can also see an overview of your licenses for all installations on the same SLC. You can open the License Information window in the Site Navigation pane -> Basics node -> License Information.
License types
Der er flere licenstyper i XProtect-licenssystemet.
Basislicenser
Som minimum skal du have en basislicens til et af XProtect VMS-produkterne. Du kan også have en eller flere basislicenser til XProtect-udvidelser.
Enhedslicenser
Som minimum skal du have flere enhedslicenser. Generelt har du brug for en enhedslicens for hver hardware-enhed med et kamera, du ønsker at føje til dit system. Der kan dog være forskel på hardware-enheder, og det afhænger af om hardware-enheden er en Milestone-understøttet hardware-enhed eller ej. For yderligere oplysninger, se Understøttede hardware-enheder og Ikke-understøttede hardware-enheder.
Hvis du ønsker at bruge funktonen video-push i XProtect Mobile, skal du også bruge en enhedslicens for hver mobile enhed eller tablet, som skal kunne foretage video-push til dit system.
Enhedslicenser er ikke nødvendige til højttalere, mikrofoner og input/output-enheder, som er knyttet til dine kameraer.
Generelt har du brug for en enhedslicens for hver hardware-enhed med et kamera, du ønsker at føje til dit system. Enkelte understøttede hardware-enheder kræver dog mere end en enhedslicens. Du kan se hvor mange enhedslicenser dine hardware-enheder kræver i listen over understøttet hardware på Milestone-websitet (https://www.milestonesys.com/support/tools-and-references/supported-devices/).
For videokodere med op til 16 kanaler har du kun brug for én enhedslicens for hver videokoder-IP-adresse. En videokoder kan have en eller flere IP-adresser.
Hvis en videokoder derimod har mere end 16 kanaler, så kræves der en enhedslicens for hvert aktiveret kamera på videokoderen - også for de første 16 aktiverede kameraer.
En ikke-understøttet hardware-enhed kræver en enhedslicens for hvert aktiveret kamera, der bruger en videokanal.
Ikke-understøttede hardware-enheder bliver ikke vist i listen over understøtet hardware på Milestone-websitet (https://www.milestonesys.com/support/tools-and-references/supported-devices/).
Kameralicenser for Milestone Interconnect™
For at køre Milestone Interconnect, skal du bruge Milestone Interconnect-kameralicenser på dit centrale system for at se video fra hardware-enheder på fjernsystemet. Antallet af krævede Milestone Interconnect-kameralicenser afhænger af antallet af hardware-enheder på de fjernsystemer, du ønsker at modtage data fra. Det er kun XProtect Corporate, der kan fungere som centralt system.
Licenser til XProtect-udvidelser
De fleste XProtect-udvidelser kræver yderligere licenstyper. Softwarelicensfilen indeholder også oplysninger om dine produktudvidelseslicenser. Nogle produktudvidelser har deres egne separate softwarelicensfiler.
- XProtect Access (se XProtect Access licenses)
- XProtect LPR (se XProtect LPR licenses)
- XProtect Transact (se Before you start)
XProtect Smart Wall kræver følgende videovæg-relaterede licenser:
- En basislicens til XProtect Smart Wall, der dækker et ubegrænset antal skærme, som viser video på en videovæg
Brug af XProtect Smart Wall er kun understøttet af disse produkter:
XProtect Corporate - en basislicens til XProtect Smart Wall er inkluderet i basislicensen
XProtect Expert - køb en basislicens til XProtect Smart Wall separat
XProtect Incident Manager kræver følgende licenser:
- En basislicens, som dækker den fulde brug af XProtect Incident Manager
Brugen af XProtect Incident Manager er kun understøttet i de følgende VMS-produkter og -versioner:
XProtect Corporate 2022 R2 og senere: en basislicens til XProtect Incident Manager er inkluderet
XProtect Expert, XProtect Professional+ og XProtect Express+ 2022 R3 og senere: køb en basislicens til XProtect Incident Manager separat
