Blank screen monitoring (explained)
Blank screen monitoring is an operation mode where operators only see video when a situation requires their attention. The video wall does not display any cameras during normal operation. Only when an event occurs does the video wall display video from the related cameras. When the incident has been resolved, the monitors showing the video are cleared.
To enable blank screen monitoring, you must create and apply a preset
XProtect Smart Client 中一個或多個 Smart Wall 監視器的預先定義的版面配置。預設點可決定顯示哪些攝影機,以及內容如何建構在視訊牆上的每個監視螢幕上。 that only has a view layout, but no cameras. Use rules to display the cameras associated with certain events on your video wall, then clear the monitors again. See also Create rules with Smart Wall presets.
