Sound Settings (Alarms node)
When you configure sound settings, specify the following:
                                             Name  |
                                             Description  |
| Sounds |
                                             Select the sound to be associated with the alarm. The list of sounds contains a number of default Windows sounds. You can also add new sounds (.wav or .mp3).  |
| Add |
                                             Add sounds. Browse the sound file and upload one or several .wav or .mp3 files.  |
| Remove |
                                             Remove a selected sound from the list of manually added sounds. Default sounds cannot be removed.  |
| Test |
                                             Test the sound. In the list, select the sound. The sound plays once.  |
