Issue: A parent node in a Milestone Federated Architecture setup cannot connect to a child node
If you have renamed the host computer of a site that acts as a child node in a Milestone Federated Architecture, a parent node will not be able to connect to it.
To reestablish the connection between parent node and site
                                    Detach the affected site from its parent. For more information, see Detach a site from the hierarchy.
                                    Re-attach the site using the new name of its host. For more information, see Add site to hierarchy.
To make sure that the changes are in effect, you might want to stop and restart the Management Client on the node that serve as a parent node to the one whose host name has been changed. For more information, see Start or stop the Management Server service.
For more information about the implications of a host name change in a Milestone Federated Architecture setup, see Host name changes in a Milestone Federated Architecture.
