Blank screen monitoring (explained)
Blank screen monitoring is an operation mode where operators only see video when a situation requires their attention. The video wall does not display any cameras during normal operation. Only when an event occurs does the video wall display video from the related cameras. When the incident has been resolved, the monitors showing the video are cleared.
To enable blank screen monitoring, you must create and apply a preset
Een vooraf gedefinieerde indeling voor een of meer Smart Wall-schermen in XProtect Smart Client. Voorkeurinstellingen bepalen welke camera’s worden weergegeven en hoe de inhoud op ieder scherm in de videowall wordt ingedeeld. that only has a view layout, but no cameras. Use rules to display the cameras associated with certain events on your video wall, then clear the monitors again. See also Create rules with Smart Wall presets.
