Using the timeline in playback mode (explained)
In XProtect Web Client, you can use the timeline to quickly search and identify recordings.
On the Views tab:
Find and click a camera or a view with cameras. The timeline is available in both single-camera and multiple-camera views.
Switch to playback mode to show the timeline, then use the timeline controls to do the following:
Item |
What can I do with it? |
Click and hold the playback slider, then drag it to the left or right. Release the playback slider to start playing the recording at the time chosen. |
In live mode, view the video's current time on the current time indicator in the bottom-left corner of the camera view pane. Click to open the time picker and select a time and date to go to a specific point in time in the video. |
In playback mode, view the selected time of the recording on the time indicator in the center of the timeline. Click to open the time picker and select a time and date to go to a specific point in time in the video. (see Specify time for video playback). |
Play the recording backward or forward. |
Pause the playback of the recording. |
Go to the previous or the next sequence. |
Quickly switch between live and playback modes. Hide or show the timeline. |
Click the question mark icon to open the Color codes legend of the timeline:
In the bottom-left corner of the timeline, drag the speed slider to the left or click the minus sign to slow down playback. Drag the speed slider to the right or click the plus sign to speed up playback. The default value is x1. |
In the bottom-right corner of the timeline, drag the time slider to the left or click the minus sign to reduce the time span for playing back the video. Drag the time slider to the right or click the plus sign to increase the time span for playing back the video. |
